Every time i try to open my refit file a screen pops up with said that a problem caused by the program made refit shut down and then it gives me the option te either close te program completely or debug the program. has anyone had this problem.
I could really use your help.
I need to hand in my project next week.
Gelöst! Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
the model opens fine in 2020. You probably need to reinstall Revit.
...you might want to try a repair first.
I can use revit 2019 from school, but i can't download anything else. Would it be possible that you save the file in a older version of revit and send it to me?
Revit can't do that.
I can open the model fine (without upgrading) in Revit 2019.2.2 with Audit checked upon opening. I would try the Audit option and see if that resolves the issue. I would also check to see if your school could install all the updates for 2019. If you are on 2019.2.2 then I would start to think there is something on the machine you are using that is in conflict with Revit.
