Broken Door Family
Broken Door Family
Hi Everyone
I've downloaded this door family from a local supplier. When trying to use and modify the family, the door size changes, but the frame doesn't. More specifically, when changing the door size to a 1020mm wide door, the frame opening doesn't change.
I've tried playing around with the family, but i cant seem to pin point why this is happening. Any advice would be great. Thanks
Seems to flex fine for me.  I can see how you could break it, depending on which named TYPE you are modifying.  But, I'm curious why you are entering a width. The family has 10 Types already defined in it.  I suspect those are all the stock sizes that the Manufacturer offers.  Do none of those TYPES work for you?
BTW: I just tried 1020 Width with every Type and Style and it didn't break on me.
Type a product name
