Plan view of wall wrapping not showing property when the brick skinn is extended to meet footing. If I remove the bass extension distance from the wall it wraps properly. anybody know of a fix for this?
wall wrapping works in 3d just not plan views???
Can you post a screenshot of the wall properties? It looks like all layers are within the Core Boundary.
so this hasn't been fixed since 2016?
The best work around was manually changing wall joins to miter, luckily this project its big.
