No matter what I do this brick hatch will not go away
yes I have tried everything I can think of: edited the materials, change the visibility grahics override - I even started a new generic wall and replaced the entire wall with a blank grey generic wall - somehow it remains
however in one sectional drawing it does not appear and appears as I wanted it to as a flat colour - but I have compared every setting between them and they are all the same - the weird thing is that I also changed the weatherboard patterns and they changed without resistance at all. the only thing my efforts did change is giving me the backgroud colour behind the hatch pattern
things tried:
- wall edit setting and materials
- visibility graphics overrides
- doing a new generic wall and replacing this one
- painting over the top with new material
- removing paint - all that does is leave the brick pattern and take out the grey background colour
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Looks like a Bump or Relief. Go to Object Styles, scroll down to "Walls" and see what's listed under "Material" column. Is there a Material there? Edit it and expand the Bump and/or Relief Categories under the Appearance Tab. See any Images?
try to post the part wall here so we can check? thanks
You have Overridden Material by Element (Surface Pattern)...
champion thanks heaps that was the one thing I missed
this is an older drawing and I was sort of cheating back then with the visibility overrides rather than doing the materials properly - and I forgot about that
Cheers
