Breaking linked models plan view with removal of annotion
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
raythong980707075652
677 Aufrufe, 21 Antworten
Hello to the community,
I liked to break my plan into for example 3 different section, I managed to break them with crop view but the problem with this is, the annotation remains in the viewport as shown in attached image, how can I remove them? I followed on of the forum stating to use it as a dependent view, but both method simply doesn't solve my issue. As stated in the title, this is a linked between multiple models linked in as an Attachment. The annotations are all done in their own respective view with a view template in place.
As you can see in the image Annotation Removal 2, when I move the view closer together, the annotation doesn't go away but it also becomes haywire. Is there anything that I can do to fix this issue?
Regards and Thank you,
Raymond Thong
21 ANTWORTEN 21
Nachricht 2 von 22
rxi.gg
als Antwort auf: raythong980707075652
You have forgotten to upload the image, mate.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 22
Here is the image
Nachricht 4 von 22
rxi.gg
The only idea that I have is to try with masking regions.
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-3BA1B0F7-24C9-40C5-9F1F-3C459B693B91
Nachricht 5 von 22
als Antwort auf: rxi.gg
@rxi.gg sadly it did not work out, Masked Region only works for the parts in the crop region and not the part that's outside.
Nachricht 6 von 22
Is the Linked Model being shown in the Parent View BY LINKED VIEW?
Nachricht 7 von 22
@barthbradley yes it is
Nachricht 8 von 22
Change the Link Display from By Linked View to Custom so that you can turn off or hide unwanted annotation.
Or, you can open the link, create a dependent view, break it the same way, save/reload the link, and choose this broken view for Display By Linked View.
Nachricht 9 von 22
Create a Symbol Family that contains parametric Masking Region, load it into Project and place over the stuff you want covered up and size the Masking Region to the necessary size using the Parameters.
By "Symbol Family", I mean Generic Annotation Family.
Nachricht 10 von 22
als Antwort auf: ToanDN
@ToanDN Hey ToanDN, I did think of that option but the problem is they are duplicates of each other, so even if I make it custom, all of the annotation would just be turned off.
Nachricht 11 von 22
The results I am trying to come out was something like this.
But this is through stitching multiple dependent view together in the Sheets, is there another work-around for this?
Nachricht 12 von 22
I created a parametric Masked region via Generic Annotation Family, but since it is in the crop region, it doesn't work out the way I want it.
Nachricht 13 von 22
Aren't you Breaking the Crop Boundary into two or more Region and then moving the Regions closer together?
...and with a Link that is displayed BY LINKED VIEW?
Nachricht 14 von 22
yes exactly this, but the grids and annotation remain the the drawing, I liked to remove the annotation in the break.
Nachricht 15 von 22
Masking GA Symbol should work.
Nachricht 16 von 22
@barthbradley
If I move them closer, the annotation just doesn't crop together like they would in the the outer box.
Nachricht 17 von 22
You need to fidget with it.   Post your file if you want me to look at it.
Nachricht 18 von 22
Nachricht 19 von 22
C'mon, can't you just post the files here? I hate downloading files from people/sources I don't know personally/professionally.  No offense to you. I'm just weird that way.
Nachricht 20 von 22
Place this family on sheet and stretch to mask the gap.  2022 version.
before:
after:
