Does someone know if REVIT 2016 allows for a breakline to ramps same as for stairs? The older versions of REVIT did not.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
breaklines for stairs exists natively in Revit
breaklines for ramps does not exist (must be written into the program)
you can use a 2D detail component (breakline) and try to use it
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
hi, if you want you can try this:
http://autodesk-revit.blogspot.sg/2008/03/ramps-dont-cut.html
no worries...
@Anonymous
Were you using a masking region to mask the above part of the ramp? What if you have any objects under the ramp such as equipment or floor finish pattern? Would they be masked as well?
Yes, I am using masking region.
Unfortunately that hides all that is under the ramp as you say but there is no other way around it.
Of course there are other ways around it. Here's one:
- Override graphic of the ramp and make it 100% Transparent and with dashed outline.
- Draw a masking region to cover the lower part of the ramp so that anything below the upper part are still visible.
Hello, i am looking for answers on this poste because i would like to know how in Revit 2023, it is possible to get a cutting line on a concentric ramp.
