Hello guys,
I have a problem with one of my familly. It's a Lighting fixture, to which I need to attach the bracket. The issue is that it only works when the lighting fixture is straight, but when i change angle of fixture, the bracket doesn't follow up. Any advice? I attach the rvt familly below. Thank you!
Hi @Anonymous
Have you tried adding the Bracket to the Base Geometry Family?
What's up? Hard to tell what the geometry's orientation is supposed to be. I'm guessing the orientation in the second screenshot is correct. If so, turn the geometry 90 degrees and reload it into the Parent Family. But, I would really suggest using a Face-Based Template to create the Parent, as shown in second screenshot.
Make it work plane-base, untick always vertical, and set the work plane on the reference line.
