BPAC certificate completed WITH NO CERTIFICATE PLEASE HELP
4 ANTWORTEN 4
Nachricht 1 von 5
455 Aufrufe, 4 Antworten
Please I need support,
I just finished Autodesk Building Performance Analysis Certification courses. After I completed the mandatory survey in the end of 7 courses I noticed that to write the code as it is appear, but there were no codes, then I went through the next page (Final BPAC Quiz) then, Failed. I cannot take the certification tell I complete (Final BPAC Quiz) which need the mentioned code.
Please advice.
Tags (2)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Please advice.
Read through the other post that you just commented in.  Your answers are there.
Nachricht 3 von 5
Thanks, Problem solved
Nachricht 4 von 5
What is the solution to this? If you missed the code which you have to enter for the final BPAC quiz?
Nachricht 5 von 5
Just send an email to bpac team and they will solve the problem.
