Bottom Railing
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jjjoao2
396 Aufrufe, 2 Antworten
Bottom Railing
I would like to create a railing and the part below it should go around the treads and the risers on the steps, as shown in the attached image. Is it possible? How can i draw it?
2 ANTWORTEN 2
Nachricht 2 von 3
hmunsell
als Antwort auf: jjjoao2
check this post out....
https://forums.autodesk.com/t5/revit-architecture-forum/railing-to-follow-step-of-stairs/m-p/9257692
Howard Munsell
Nachricht 3 von 3
Quickest way to do to it is an In-Place Component using a Sweep.  Couple of minutes work -- tops.
