Bonding compound wall material to instance parameter.
17 ANTWORTEN 17
Nachricht 1 von 18
875 Aufrufe, 17 Antworten
revit newbie here (and english it's not my native tongue, so i'll try to be as clear as possibile), i'm trying to figure out, for scheduling purpouse, if it was possible to "bond" the compund layers material's to an "exposed" instance parameter for a given element.
i'll try to be more specific by providing an example:
let's say i've a compund wall made by: finishing1, structure, finishing2
i've already created "n" instance parameters called ".01" ".02" ".03"-->".n"
would it be possibile (using, i think, global params) to show in the element properties the layer material like ".01=finishing1" ".02=structure" ".03=finishing2"?
i've figured it out a solution by using dynamo, but it is not a real "bonding" but something more like a "print"; so it is not a continuos relation, but just a text value: if i change "structure" with "substrate" the ".02" parameter will show the previous value until i run the dynamo script again.
after some days of trial and error i've almost gave up, but i just want to be sure that there's no way to get to this behavior.
p.s.: my final goal is not a bidirectional bonding. i don't want to be able to modify the compound wall material by the instance properties, i just want to be able to "read" the material without needing to enter in the compund structure view.
thanks for your time.
Beschriftungen (3)
17 ANTWORTEN 17
Nachricht 2 von 18
als Antwort auf: Anonymous
Couldn't you accomplish through Material Naming and a Material Takeoff Schedule?
Still, I am not really clear why you are doing this.  How does it aid you in scheduling?
...what about Parts for this?  That might get you there.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Nachricht 3 von 18
Long and short you just want the wall type to list all the layers of the wall. Correct?
Nachricht 4 von 18
als Antwort auf: ToanDN
yes, LOL.
i love how you synthetised my wall of text.
Nachricht 5 von 18
als Antwort auf: barthbradley
thanks! i'll give it a look asap
Nachricht 6 von 18
i'm sorry to bother you, do you think is there  away to obtain that?
Nachricht 7 von 18
Use a Material Takeoff Schedule for Wall Category.
Start here and drill down:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Nachricht 8 von 18
i'm sorry. probably was not clear in my first message.
i know how to use schedules and how to do quantity take off.
i do aim to something different.
i would like to "show" in the elements properties the materials that the element is composed of.
in particular i would like to associate that information to a parameter set by me.
Nachricht 9 von 18
as an example.
in the type properties of a wall you can see the parameter "materials and finishes" and that parameter shows the core/structural material if a compound structure is used.
i was wondering if it was possibile to show, ALL the materials of the compound structure and associate them with a custom created parameter.
Nachricht 10 von 18
Lachlan-JWP
That sounds like a Wall Type...
Nachricht 11 von 18
als Antwort auf: Lachlan-JWP
Yeah, doesn't it?
Nachricht 12 von 18
well, ok.
as said in the first post newbie and non-native english speaker are a bad combination, probably.
i'll try to use some pictures.
my final aim is to show in the type properties the material layers of wich is composed the compound structure, as it happens with the "material and finish" parameter (in green).
is it possibile to obtain the same result?
i don't need to be able to set the layer material from outside the structure dialogue window, just to match the layer to a given parameter
Nachricht 13 von 18
Are you aware that "Structural Material" and "Structure[1]" are two different things?
Out of curiosity, why do you want to do this? Maybe, just maybe, we can get you there another way.
Nachricht 14 von 18
yes i am, but i don't get how this should be related.
as said and shown in the pic, i just wanted to see (or to know if it was somohow possibile) all the materials of the compound structure, as it happens OOTB for the material marked as "structural".
about the other question.
i need to be able to associate the material to a parameter.
i can do that by reading it and writing it via dynamo.
but i do need those are continously connected, so that in case i do change the material layer also the information in that parameter changes.
Nachricht 15 von 18
BDMackey
After seeing your image yes you can get what you are thinking within Revit.  Your parameter "a" would need to be a material parameter, looks like it is a text parameter.  Once it is a material parameter it will allow you to associate that to a Global Parameter.  It will obviously be up to you to map them to the appropriate Global Parameter.  Only certain types of parameters can be mapped to a global, text isn't one of those.
Nachricht 16 von 18
als Antwort auf: BDMackey
yes, that's what i was thinking.
still i'm not able to locate the correct parameter to map :enttäuschtes_Gesicht:
Nachricht 17 von 18
You need Dynamo to do it.
Nachricht 18 von 18
for sure i can achive the objective via dynamo.
but as said before, i think it would be just a "one time" setting.
do you think is there a way to link them in a continous way?
with continous way i mean: i change the material, the parameter changes without re-running the script.
