Blend between two circles in different elevation
33 ANTWORTEN 33
GELÖST
Nachricht 1 von 34
Purus_Cdds
1609 Aufrufe, 33 Antworten
I am trying to blend between two circles. but the blend curve is not straight as i marked. Why not?
Your help is appreciated.
33 ANTWORTEN 33
Nachricht 2 von 34
als Antwort auf: Purus_Cdds
A blend doesn't work that way. It only has two opposing profiles.  You need to loft it.  Mass environment.
...or use 2 blends; stacked.
Nachricht 3 von 34
ramabalanv
@Purus_Cdds,
I guess, out of your two circles (profile),  one circle(profile) is splitted. Thats why the blend profile is curvy. If you use circle for two sketches without any split, the path of the blend will be straight.
Nachricht 4 von 34
Nachricht 5 von 34
Purus_Cdds
als Antwort auf: ramabalanv
That is not the case. i have both circles no (2) arcs.
Nachricht 6 von 34
Purus_Cdds
als Antwort auf: barthbradley
Can you please check the attached rfa file?
Nachricht 7 von 34
You used the wrong tool.  Don't use a Blend. Use a Sweep Blend or Revolve.
...you want it to look like this; right?  Sweep Blend shown.
Nachricht 8 von 34
Purus_Cdds
Please check in front view. I need 9" offset between center to center as shown in the image below.
Nachricht 9 von 34
Okay...then use a Blend.  I thought you wanted a conical shape.  You're not going to get a conical shape unless the profiles remain perpendicular to the path.
Nachricht 10 von 34
Create two halves and join.
Nachricht 11 von 34
als Antwort auf: ToanDN
@Purus_Cdds: So this is the shape you're trying the achieve?
Elevation View:
Nachricht 12 von 34
@Purus_Cdds: I notice the your family is named Catch Basin, and that it's 10'-0" deep.  Is this a manhole?  Is so, may I submit that only one side is tapered; that the other side is parallel to, and in-line with the manhole side wall below it (the side with the ladder steps).   Something like is shown in this picture:
Nachricht 13 von 34
Purus_Cdds
That works..! I am happy with this solution but there must be a different way.
Nachricht 14 von 34
Purus_Cdds
Yes! that is a man hole for storm pipes.
Nachricht 15 von 34
Well, I hate to tell you, but is that's your design objective, then your math is off.  Should be a 8" not 9" offset from center with a 3'-6" dia. man opening and a 4'-10" dia throat opening.  With 9", you have a 1 degree taper on the side opposite the major taper.  You want zero taper on that side.  Not knit-picking. Just pointing out a possible design error, that could come back to bite you in the butt.  And, it's all free advice too.  How about that?
Nachricht 16 von 34
Ha! Yah, @ToanDN; there must be a different way! Can you work on a few more solutions and get those submitted for approval by the 8:00 AM PST? Thanks. You're the best, man.    Smiley (zwinkernd)
Nachricht 17 von 34
Hey!!! I figured out how to do the eccentric using a Sweep Blend, and it was pretty fricking easy too! Anybody still interested?  Or, are we done here?
If so, I'll share the trick with you...
Nachricht 18 von 34
You mean this?
Nachricht 19 von 34
...maybe. maybe not. Smiley (zwinkernd)
...show me sketch mode for the top profile.
BTW @ToanDN: that's exactly what I showed above (the conical shape uses this approach).
Nachricht 20 von 34
