Hi, i was wondering if there is a tool in revit that works like "blend" in autocad for two splines.
and also how can i trim with a radius?
No, there isn't. The closest that you could get would be by connecting the two splines with an arc.
Maybe reconstruct it using a mass as a bridge.
I realized I could not attache two screencast in one post.
To Trim with Radius, use Fillet Arc tool.
@tpreisler wrote:
Thanks , what about trim with a radius?
See above.
And I feel stupid... why would I need to use a mass to draw the spline? Just redraw it directly over the two existing ones lol
Here's why - under Detail Lines you don't get a Spline Through Points option. The control points option will not give you the option to create an exact spline. Unless I'm missing something.
