Hi everyone,
hope you are all well.
I'm experiencing a graphic issue with Revit (2023). When I export PDFs, plans with colour scheme applied (areas) show white blank spots. Interestingly, those spots reflect walls on the level below. I checked all the settings and I could not come up with a solution.
Anyone experienced the same problem? See image attached
NB: when working on Revit I see everything properly.
Sounds like a PDF/settings issue. Maybe different PDF Printer or try Export to PDF. BTW, are you Raster Processing?
It might be a good idea to check the height of your walls on the lower floor if it's reflecting the placement of them. Is it possible they are too high?
