Blacked out finish surface in 3d view.
2 ANTWORTEN 2
Nachricht 1 von 3
vygantas_kelpsa
186 Aufrufe, 2 Antworten
Imported new family ruukki sandwitch panels. Then I put walls on my project in 3D view walls finish layers shows as blacked out. No mater if detail level is set on fine/medium/coarse, no mater if visual style is set to wireframe/hidden line/shaded/consistent colors/realistic finish layer on my wall sample is blacked out.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: vygantas_kelpsa
What is the material?
Nachricht 3 von 3
syman2000
Check the material and see if you have surface material set to solid black
If that didn't work, check in your Visibility and graphic and go to wall. Then click on the surface and clear override.
