Need help with massive black dot in viewport when printing at 1:50. When printing at 1:100 there is no problem
Turn off Thins Lines and select the Element to find out what it is and where its coming from. Once you find it, you can fix it.
Hi @Anonymous
Did the recommendation by @barthbradley help?
Please share the file, version of revit you use and let us know if you've applied the latest hotfix for your Revit version.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
