Bind Link doesnt work
3 ANTWORTEN 3
Nachricht 1 von 4
1611 Aufrufe, 3 Antworten
I have trouble binding link into revit file.
Linked file is not very big - 34MB. Neither is file that it is linked in - 40MB.
I keep getting the same error
Unable to bind the selected links.
Workset1 : RVT Links : Linked Revit Model : JM2_3B_A.rvt : 48 : location Internal - Name 48 : id 2812655
Unable to bind some link instances. Either the link contains no 3d elements or there was an error loading its elements into the current project.
I've tried purging everything in linked model, ungrouped all groups in it. Checked if every element has Phase Created set. Also unlinked all nested links in it, before trying again and again. Doesn't work. Also sifted through forums -  tried some other approaches - it just won't bind it.
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
hello, you can try to refer to these LINK and LINK and see if helps. thanks
Nachricht 3 von 4
als Antwort auf: ennujozlagam
Revit does highlight in orange some elements in link that seem to be breaking binding operation.
Though, deleting these highlighted elements, synchronizing and then reloading link before trying to bind also does not help.
After this process Revit just highlights some other elements in link in orange. It also highlights level 00.
Nachricht 4 von 4
rafal.lewandowski
Hi @Anonymous! Is there a chance to receive a model from you that contains these errors? There may be several reasons for this, and without model will be difficult for me to determine what the cause is. Please look at your mailbox. I have sent you an email. Thanks!
