BimObject lighting is not working correctly
ModernArchWorld
Message 1 of 9
ModernArchWorld
I usually use Lighting from Bim Object to my Revit project but when I upgrade Revit 2018.3, I can't use BimObject Lighting correctly into Revit project. Please see my attach file that how look like in project. I am not sure what do I need to install. Thanks
Replies (8)
Message 2 of 9
Post the family you downloaded from BIMObject
...also, you need to explain what you mean by "not working correctly".  That could mean anything.
Message 3 of 9
ModernArchWorld
  • Lighting is Up to top of Roof instead of Down from Ceiling like the Black Lights.Lighting is Up to top of Roof instead of Down from Ceiling like the Black Lights.Please check Lighting white one at the top of roof. The black Lights and originals. The White one is from BimObject. When I try to put Lighting, Its not installed correctly.
Message 4 of 9
Sounds like a hosting issue. Is that right? Post the Revit file that you created this screenshot from.
Message 5 of 9
syman2000
BIMObject lighting typically host by face or by workplane. So most likely you placed it accidentally on the roof.
Message 6 of 9
ModernArchWorld
I put on Ceiling,Also I notice that when I try to put Wall Light, that also come with opposite 😞
Message 7 of 9
syman2000
If you run into that issue, I would simply create another lighting family with no host, then load the BIMobject family into the new family. Create small host object like box so you can host the object. Then Turn off the host object and load in your family. This is how I get around their shortcoming and save time instead of trying to figure out how to make it right.
Message 8 of 9
Toggle your Flip Work Plane control
Message 9 of 9
Really be best to post the Family for us to inspect.
