BIM Interoperability Tools - RVT Links Worksets
reut.h
reut.h
I have a check set file defined in the BIM Interoperability Tools.
Im trying to add a new check in the model checker that will lists and count all the RVT Links in my model & their Worksets. For some reason it won't work - I tried various conditions but it didn't work.
Select the link, edit type and see which workset is assigned.
JasonKunkel
The values in the Model Checker Report are hardcoded, and you cannot add parameters to them. So while you can certainly get a list of all the linked models, you cannot display the Workset.
If you know what Worksets they should be ahead of time, b/c of standards for example, you could create checks that report linked models that are not on the expected Workset.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
reut.h
Thank you, Jason.
Thats a shame, Good to know. Hope this will be available soon.
