BIM INTEROPERABILITY TOOLS - Duplicated elements check not working
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
karina.honda47NN4
1059 Aufrufe, 4 Antworten
Hello guys!
I'm trying to use a duplicated elements check on BIT but it's not working, a fail message with redundant criteria is appearing
4 ANTWORTEN 4
Nachricht 2 von 5
JasonKunkel
als Antwort auf: karina.honda47NN4
Please look at any of the Revit Model Best Practices checksets in the Public Library for a duplicate element check that won't error. It's not perfect, the location redundant check is always a little finicky, but it mostly works and no need to make something that is already made.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 3 von 5
tnievesP53K8
als Antwort auf: JasonKunkel
is there some way to copy across checks because I'm trying to make one that simply lists out all instances of duplicates, and a few other types of lists that I can simply use for reviewing models or give to the model teams.
Nachricht 4 von 5
JasonKunkel
When you say "copy across checks" do you mean:
1. take the results of one check and compare to the results of another check
or do you mean
2. create one check and copy it to easily edit it
1. is not possible, but 2 is.
And you might mean 3. which is something I have not captured above.
Jason Kunkel
Nachricht 5 von 5
T52K-BIB
@karina.honda47NN4 I used Match RegEx with the value
\s\d+$
\s matches a space character.
\d+ matches one or more digits.
$ asserts the end of the string.
