BIM Glue with different versions of Revit
BEE_Design
BEE_Design
Can i upload to the same BIM Glue project with different versions of Revit?
lets say:
upload dwf created in Revit 2017, lets say from ARC.rvt
upload nwc created in Revit 2014, lets say from STR.rvt
Also,
whilst I'm here, is there any issues with linking files within Revit from different versions of Revit? e.g. linking a Revit 2014 file into a Revit 2017 file?
SY
Chasing BIM Architect ideal in HK with GeForce GTX 660 Ti, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 16.00 GB RAM, Mircrosoft Windows 10 Home.
N.Oomen
Hi BEE_Design,
It is possible to upload with different versions of Revit to BIM360 Glue as long as you have acces to your BIM360 Addinn in your specific versions of Revit.
The published product (model) within BIM360 Glue will be a DWF or NWC. Those are not related to Revit versions anymore.
For your second question,
When you link a Revit 2016 Model to your model in Revit 2017, Revit will always temporarily update your linked model to the newer version.
Every time you will start your Revit 2017 Model it will again update your links to the newer version.
This shouldn’t give you any problems, since updating files works well the last couple years.
Good Luck, I would really like to hear if this helps you out.
Niels Oomen
Best regards,
Niels Oomen
Cadac Group BV
Sr Consultant AEC
