BIM 360 Team is stuck in "loading".
30 ANTWORTEN 30
GELÖST
Nachricht 1 von 31
alfonzogary
17567 Aufrufe, 30 Antworten
My Revit 2017 and 2018 are not loading my BIM 360 Team folders. I click the icon and it just gets stuck in "loading" and never moves past that.
30 ANTWORTEN 30
Nachricht 2 von 31
Viveka_CD
als Antwort auf: alfonzogary
Hi @alfonzogary
Can you post a screenshot of what you are seeing?
Is your Revit updated to the latest builds?
Which windows version are you on?
Please see this article: BIM 360 Team keeps Loading in Revit for recommendations.
Let me know if this helps resolve your issue.
Tags (1)
Nachricht 3 von 31
alfonzogary
als Antwort auf: Viveka_CD
@Viveka_CD wrote:
Hi @alfonzogary
Windows 7, and yes I have the latest as far as I know Revit 2017.2
Nachricht 4 von 31
Viveka_CD
Hi @alfonzogary
Did you see this article for recommendations and try to adjust your internet settings?
Nachricht 5 von 31
Alfredo_Medina
Try this:
  • Logout of your Autodesk account.
  • Restart Revit
  • Log on again.
Also, make sure that:
  • your BIM 360 Team account is in good standing (that you have access).
  • that the Revit model is still in the same version that you have
Nachricht 6 von 31
alfonzogary
Yes I tried the settings. The IT guy is checking the server.
Nachricht 7 von 31
Viveka_CD
Hi @alfonzogary
Let me know your IT is able to fix this internet settings issue.
Nachricht 8 von 31
alfonzogary
Okay, he said there are some window server security updates he is installing on the server. Maybe after that everything will be back to normal. I'll post the results.
Nachricht 9 von 31
alfonzogary
That fixed it. Security updates on the server. Once those were installed everything started running normal. Thanks for your time.
Nachricht 10 von 31
Viveka_CD
Hi @alfonzogary
Awesome, Thanks for getting back to us! Glad to hear that your issue is fixed. Smiley (fröhlich)
Nachricht 11 von 31
als Antwort auf: Alfredo_Medina
Hello Alfredo,
been having this issue with all my team mates. Went through all the required steps but no result still .
Nachricht 12 von 31
ZakMDMSN6
Hi There, @Viveka_CD
Our entire office is having the same issue. The BIM 360 is not showing up. I checked and everything was update on my window. Could you please let me know how can I get it fix or contact someone?
Best,
Zak
Nachricht 13 von 31
Viveka_CD
als Antwort auf: ZakMDMSN6
Hi @ZakMDMSN6
Please install the patch for the TLS issue, see Transport Layer Security (TLS): Updates Required to Maintain Software Access
If the above fix does not help, please try the below
  1. Move the Revit.exe.config file from the C:\Program Files\Autodesk\Revit 20XX folder to a location outside the Revit Programs Files folder (e.g. the Desktop).
  2. In the Windows Control Panel, repair the Revit install (NOT the Collaboration for Revit install). This will result in the creation of a new Revit.exe.config file.
  3. Alternatively you could replace the affected config file with one from computer where the Revit works properly
Let me know if this helps and if you have additional questions.
Nachricht 14 von 31
can you show me tutorial step by step?
Nachricht 15 von 31
achusetiawan
Nachricht 16 von 31
als Antwort auf: achusetiawan
thank you, this works!!:grinsendes_Gesicht_mit_lächelnden_Augen:
Nachricht 17 von 31
works really well fro me! saved my life lol
Nachricht 18 von 31
Any chance you have a link for 2019? Haven't been able to find one. Thank you!!!
Nachricht 19 von 31
reinems74
als Antwort auf: Anonymous
The recommendation is to download the necessary patches from the Account portal, or through the Autodesk Desktop App. Here is our page on 2019 patches: https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-tran.... Are you able to access what you need from there?
Scott
Scott Reinemann
Revit Development
Nachricht 20 von 31
als Antwort auf: reinems74
I don't believe the download I'm looking for is showing up under "all products" in the portal and the desktop app. What would be the name of the patch that will fix this problem for Revit 2019?
