BIM 360 Button from Open dialog
10 ANTWORTEN 10
Nachricht 1 von 11
adcdao
480 Aufrufe, 10 Antworten
Hi everyone,
I'm actually testing Bim360 Team. I have an account and I can access my project from the Web portal. I also installed Autodesk Desktop Connector. I'm able to open my Revit project using browse and then navigate to the Bim 360 Team folder.
But when I click on Bim 360 button I have a message indicating I'm not allowed to access Autodesk Collaboration for Revit.
What I' doing wrong?
André
10 ANTWORTEN 10
Nachricht 2 von 11
cbcarch
als Antwort auf: adcdao
Take a look here:
https://forums.autodesk.com/t5/bim-360-design-collaboration/bim-360-design-is-released-the-next-gene...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 11
Alfredo_Medina
@adcdao
BIM 360 Team is no longer available for testing or trial. Look for a trial of BIM 360 Docs, which requires Revit 2018.3 or 2019+
Nachricht 4 von 11
adcdao
als Antwort auf: Alfredo_Medina
I'm not on a trial I have a BIM 360 Team and Glue account. I update Revit to 2018.3 and I have the same problem. What is the difference between Bim 360 Team and Bim 360 Docs?
Thank you,
André
Nachricht 5 von 11
adcdao
As I understand it's also no longer possible to enable worksharing to BIM 360 Team. This option is no longer available from Revit (grayed out).
Nachricht 6 von 11
Alfredo_Medina
You need to be logged on to your BIM 360 service (you say you have an account), and you need to have a Revit cloud model in your project  in BIM 360.  Are you sure you have these 2 things and that you are logged on? Also, that your account is in good standing?
Nachricht 7 von 11
adcdao
Yes I'm logged in from everywhere. From Revit and from Autodesk Desktop Connector with the same account. From the Web application I created a new project and load an existing Revit project file from my desktop. I can see my model directly from the web app. I'm also the administrator of that project. I can load it from BIM 360 (Preview) folder but the BIM 360 button from the open dialog show me 2 choices «Bim 360 Team» and «Outils de gestion des documents BIM 360» (I have a French software). But I don't have access to neither contents. If I load my project file and try to enable worksharing, the BIM 360 Team radio button is grayed out. I have only the choice to share on LAN.
I found there's an another product «BIM 360 Design». Is this product required? Is it replacing Team? I place a request to get an account for that product.
Thank you,
André
Nachricht 8 von 11
cbcarch
Did you look at the link I posted above?
Cliff B. Collins
Nachricht 9 von 11
Alfredo_Medina
Are you sure you have a Revit cloud model in your project  in BIM 360?
By reading your reply, it seems to me that the answer is no; it seems that you uploaded a Revit model, but you have not created a cloud model yet.
Nachricht 10 von 11
adcdao
How do I create it?
Nachricht 11 von 11
adcdao
Is there any complete tutorial. It seems very complicated.
