I was not able to find Bifold-4 panel door in my family library, I thought this was a basic one that should be loaded into the project easily. Where can I find this type of door? Thanks!
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community! ![]()
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
A four-door configuration system, on the other hand, is much more convenient and can open up in one or two directions, depending on its setup. These tend to hold an area coverage of 2.9 metres
