Beyond linetype color
4 ANTWORTEN 4
Nachricht 1 von 5
KIMRAMFI
525 Aufrufe, 4 Antworten
Do I miss some point or do I have some settings wrong but when I select for <Beyond> line type the "No Color" option it will override all the beyond line types to black or white.
I understand the option that way that it would use the normal Category color if there is no color assigned to it.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: KIMRAMFI
Doesn't "No Color" just mean Black against White Background/White against Black Background? Basically, Bi-Color.
Nachricht 3 von 5
KIMRAMFI
als Antwort auf: barthbradley
Hi @barthbradley
Maybe so in this case. I am thinking it like No color override when the color is not selected. Seems silly to have black and white colors and then No Color which is basically the same.
Nachricht 4 von 5
Black is black. White is White.  No Color is Black/White, depending on Background Color.  No Color swings both ways. Smiley (zwinkernd)
Nachricht 5 von 5
Ah! I see what you mean now. No Color and Black behave the same. However, if you use a Line Color like Red with a Red Background, you can't see the Line. But, if you use No Color for the Line, it changes to White when Background is Red.
I stand corrected.  Revit is broken.  Smiley (zwinkernd)
