Beveled Countertops
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
BigPicture045
1175 Aufrufe, 5 Antworten
Beveled Countertops
I model countertops with floors. I would like to have a bevel around the edge of the countertop. As you can see in the image, the countertop I am modeling has a slight C-shaped bevel.
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: BigPicture045
@BigPicture045
What is the question? how to model the beveled edge?
Edit the family >> create a void sweep >> in 3D pick the edges of the countertop >> finish sketch >> use cut geometry
Nachricht 3 von 6
BigPicture045
als Antwort auf: RDAOU
How do you edit the family, it is a floor.
Nachricht 4 von 6
Then model in place and create a void sweep using the same method, cut geometry the floor with the void then finish the model in place.
Nachricht 5 von 6
RDAOU
@BigPicture045
That is an interesting way to model furniture and countertops! and so shall the swept void be too ... in-place.
Consistency is good...but you should consider modeling such elements as families instead
Nachricht 6 von 6
BigPicture045
I was able to put a bevel on my [Floor Element] countertops by simply using  1 Model In-Place Void Sweep. Thanks for the help.
