Best way to show Vacancy in a schedule
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
AidanHawkins
373 Aufrufe, 6 Antworten
I am using the occupancy parameter in Revit for my rooms in my office project.
If a Room is vacant - is it better to leave the parameter blank or put in a value named VACANT
I am worried about if I leave it blank I will be lost in a schedule or something
Aidan
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: AidanHawkins
If Occupancy is Number parameter then you can't show Vacant or blank but you can show 0.
Nachricht 3 von 7
AidanHawkins
als Antwort auf: ToanDN
I am showing occupancy as the name of the occupant in the room unfortunately
So im not sure what to use
Nachricht 4 von 7
Then I would show Vacant instead of blank.  If you want to show blank, you can use conditional format to make the cell a color such as black.
Nachricht 5 von 7
AidanHawkins
Okay thanks
Good advice
But if I want to show it blank, how is it possible to add a colour in conditional format?
Please see below it doesn't give me the option
Nachricht 6 von 7
Re: Best way to show Vacancy
Neon?
Nachricht 7 von 7
@AidanHawkins wrote:
Okay thanks
Good advice
You need to add a Condition to that, Test cannot be None.
Example:
