Best way to remove lines of walls where it meets and goes through topo surface
stuart
Message 1 of 9
stuart
Masters!!!!
How can I remove the lines from this area to make the section fill look consistent in section? Am I left with doing a filled region? or is there a way to do it visibility graphics/modelling differently?
Existing Building with no bim level required etc..
Replies (8)
Message 2 of 9
Avaris.
I'm not entirely sure where I'm looking at, but if you want to override lines, try linework, invisible lines. Shortcut is LW.
Message 3 of 9
stuart
The lines with the X marked on is the wall and floor going through the topo surface.
Doing the line weight will make the whole wall section line invisible?
Message 4 of 9
If its a section at a draft detail level then could you not just mask over the whole lot using a masking region?
Message 5 of 9
When doing the Linework tool you can drag the grips to set the extent of the modified part.
Message 6 of 9
Corsten.Au
Are you allowed to use Building pad?
Corsten
Building Designer
Message 7 of 9
stuart
Graeme,
This option is looking likely. Just wanted a click button option.
Message 8 of 9
stuart
ToanDN,
Any chance of a video?
Message 9 of 9
Sure.  By the way, you can only see the grips for projection lines, not cut lines.  So if your wall is cut then you need to introduce a plan region to raise the cut plane in order to see the linework grips.
https://knowledge.autodesk.com/community/screencast/33944f03-8d6f-48f7-bbb5-00d73b77979c
Screencast will be displayed here after you click Post.
