Best way to hide line/edge throughout project?
3 ANTWORTEN 3
Nachricht 1 von 4
Anonymous238
135 Aufrufe, 3 Antworten
I modeled in place an extension of the casing at this door. I can't join the 2 objects so I tried using white model lines but that doesn't work either. What's the best way to hide this throughout the project views?
3 ANTWORTEN 3
Nachricht 2 von 4
eizinmyat
als Antwort auf: Anonymous238
How about joining two objects like this? Select one and edit, copy the geometry of this one and cancel editing. Edit the other one and paste the geometry. I hope it helps you.
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
Nachricht 3 von 4
azad.Nanva
add your element to the door family or use Modify->Line Work to invisible the lines for views.
Nachricht 4 von 4
juhani.alasalmi
You should edit the door family and model the extension in the family editor. You can then join the geometry to hide the line and it will work project wide.
