we recently upgraded from revit 2019 to 2022, and there are projects we want to pull some items from. All projects are in either BIM360 or Autodesk Docs (I know "it's the same", but when it comes to accessing models, it is not the same). What would be the best approach?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
... if it is anything else other than the above, then you need to be more specific
