Best way to display Revit lines in ArcGIS? (probably and easy answer)
4 ANTWORTEN 4
Nachricht 1 von 5
seandelwhitford
381 Aufrufe, 4 Antworten
Hi all, probably an easy answer: What's the best way to display Revit lines in ArcGIS? I'm drawing septic systems and would like to represent the lines. Thank you!
4 ANTWORTEN 4
Nachricht 2 von 5
SteveKStafford
als Antwort auf: seandelwhitford
I don't use ARCGIS but this is what I find with a quick search of ARCGIS web site.
https://pro.arcgis.com/search/?q=revit%20import&collection=help&product=arcgis-pro&version=pro3.3&la...
Use their Import BIM tool.
Steve Stafford
Nachricht 3 von 5
seandelwhitford
TY: will check it out. Cheers
Nachricht 4 von 5
Export IFC from Revit and open IFC in ArcGIS.
Nachricht 5 von 5
handjonathan
Hi @seandelwhitford
Thanks a lot for posting your question to the forums!   Has the solution suggested by @SteveKStafford @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
