Best way to create urban site content in Revit
Hi Every one
Is there a way to quickly create many mass surfaces from lines imported from Autocad in Revit to later extrude volumes? When I have to create the "contexts" of my project, I spend a lot of time creating the buildings around them, even if these are simple masses and often have the same height. I have to create the lines belonging to the single building starting from the Autocad lines, create a surface and then extrude. This is repeated for each building. Some colleagues advised me to use Rhinoceros, because according to them Revit is too slow and in Rhinoceros they can select the lines via layers and extrude all the buildings together in a second. Do you know of an alternative and quick method in Revit? I hope I was clear in explaining what my problem is. Thank you.
[ The subject line of this post has been edited for clarity by @handjonathan Original: Creat Urban]
