I have created an accurate roof makeup (see below) my problem is where the fascia meets the roof construction. When i add the fascia to the roof construction it sits flush to it but obviously the tile/slate part should over sail the fascia. I have in the past just created a roof construction made up of the tile/slate part and then inset the fascia from the edge of it. This then means i need to go in and draw the roof construction when i create a section view, what am i doing wrong?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
hmm ok so if it was you, you would just create the roof construction as the tile or slate thickness and then offset the fascia in? or are you saying you don't add fascias to the 3D model at all? If you are using the 3D model for conceptual renders surely the model needs to be right? or am i missing something cheers
yeah this does seem a long winded way of getting the result, a cutting fascia would be a nice idea ![]()
