Curious if others might know the best way to do this. I want to show the tops of all the walls that you can see in the attached 3D view with the top angled similar to how its shown in the detail.
Gelöst! Gehe zur Lösung
Gelöst von Yien_Chao. Gehe zur Lösung
Draw a sloped ref plane and attach top of the walls to it.
Or are you asking how to model the coping on the sloped parapet walls?
In-Place Void Sweep cutting TOW would be one way to do it.
...or perhaps not a Void, but a Solid Geometry representing the sloped cap.
...or build the cap into the Wall Type.
I was just looking to make the cut then let the detail callout handle the cap but If I can model it in I just may do that! Thanks everyone.
I thought you want to cut the parapet walls follow the red line below? No?
No I must've used that screenshot to communicate something else to a teammate. Sorry messed you up.
