best screen for REVIT size & type
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
Soytei
20100 Aufrufe, 10 Antworten
Hi everybody,
I'd like to know what is the best type of screen and the size for REVIT & its 3d plugins like V-ray...
Could you help me with this???
Many thanks for your help in advance,
Regards.
10 ANTWORTEN 10
Nachricht 2 von 11
chrisplyler
als Antwort auf: Soytei
Well, as much screen real estate as you can get... I've got a 24" Screen I'm happy with, but I wouldn't turn down bigger.
But without making the resolution so high that the User Interface is difficult to use... soooooo, don't bother with a 4K screen or any of that fluff.
Nachricht 3 von 11
Viveka_CD
als Antwort auf: chrisplyler
Hi @Soytei
As suggested by @chrisplyler 24" (gives 3" on the side) or 21" screen size is fine, but depends on your use and preference.
  • You might run into display issues with a 4K resolution screen if you running Revit 2017 - see this article HERE for more information
  • Some desktop applications may appear blurred on high-DPI display - see HERE for more information
  • If you are using multiple monitors it is good practice to set all to the same dpi.
  • Similar post HERE
If you find posts have solved your problem, please click on 'Accept as solution' button to help others with similar questions. Kudos welcome!
Thank you,
Tags (1)
Nachricht 4 von 11
Get (3) 24": 1920 * 1080
Or (2) of the above and (1) 29": (2560*1080) in the middle
Nachricht 5 von 11
amorap
hello from Spain.
Since Revit doesnt Support more tan one monitor, my advice is get the biggest monitor you can lay over your desktop with a a very high resolution, 4K or so. In a single big monitor, you can work comfortably with revit.
I ve got 3 Benq 24" Full HD. Its a good configuration to work with 3 apps at the same time, that its a typical scenario when you are doing more tan a task at the same time  (in my case I use Revit, Cype3D for structural calculation and Arquimedes for quantity surveying), but if you want to expand Revit screen along the 3 monitors, it is a pain. Revit doesnt allow place views out of the main Revit window, you can only place out of the main window the Project browser, Properties palette and ribbon parts, but views are restricted to remain in main Revit window.
regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Nachricht 6 von 11
als Antwort auf: amorap
Revit and 3 screens - it works for me!Revit and 3 screens - it works for me!
Tags (1)
Nachricht 7 von 11
You can stretch Revit over as many screens as you want, the same as any other Windows based software.Revit and 3 screens - it works for me!Revit and 3 screens - it works for me!
Tags (1)
Nachricht 8 von 11
als Antwort auf: Anonymous
In use here 2 27" Dell monitors, resolution 2560x1440 in combination with a Nvidia Quadro 4000. I use both screens with Revit stretched. On the far right, at about 1/3 screen width the Project browser and the Properties menu, on the left monitor and 2/3 of the right monitor 3 simultanious views; the plan view, a section view and/or a 3D view or another section view of the place I'm modelling.  In that way I don't have to switch views ofthen and it works perfectly.
4K monitors are overkill in my opinion. With the 2560 resolution 27" is the minimum monitorsize, bigger is always better.
Nachricht 9 von 11
JJWGallagher
I have to agree with the 27" 2560x1440. It's the perfect size and resolution for working at a desk. Grab a 3440x1440 ultrawide if you need more space.
Nachricht 10 von 11
als Antwort auf: JJWGallagher
I prefer one ultrawide or three 16:9 monitors over two. I don't like the center of the set being a gap.
Nachricht 11 von 11
Marcin Boguslawski, what are your monitor size for these three screen of drawings? Thanks
