We have developed a set of spec models for a builder and are at the point where we need to start adding them to the actual site locations to create building permits for each lot. I can see two possible options:
1) Set up a base model with main floor at 0'-0" and xref into each site. (Does this also import the pages and all 2D information as well and can we set the geodetic import location (z particularly) to locate the model at the correct elevation?
2) Copy/Save As the base model for each client. We need to move the building and all 2D information up or down to match the new geodetic location. this is time intensive when there are up to 15 pages per building to update. (Is there an easy way to move all the 2D info on all sheets at the same time as the levels and models?)
Is there perhaps another way that I am missing? Any help would be appreciated!
