Best Practice for Tapered Roof or Floor
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
10706 Aufrufe, 10 Antworten
Below is a picture of a couple scenarios for tapered roofs that I run into a lot.  Roof 1 could also be the basis for an exterior floor deck section.  Can anyone tell me the way this is typically accomplished in Revit.  I would really appreciate some guidance.
Mike
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: Anonymous
There are several ways.
- One is:  Flat roof with variable thickness.  Edit sub elements to add slope.
Nachricht 3 von 11
als Antwort auf: ToanDN
Ditto. The way Toan describes as #1 is the best approach. Same approach we use for decking with elastomeric buildups. This way we can accurately schedule materials volume.
Nachricht 4 von 11
I must have missed one of your steps but I can't seem to generate the same effect you did.  That picture of yours is exactly what I'd like to do.
Any thoughts?
Nachricht 5 von 11
Variable layer outside the core?
Nachricht 6 von 11
Yeah, I just noticed that too. I tried that but got the same result.
-Mike
Nachricht 7 von 11
Nachricht 8 von 11
So jealous. :leicht_lächelndes_Gesicht:  Wonder what I'm doing wrong.  It's worth noting I'm also not seeing the layers.  Hmmm...
Nachricht 9 von 11
Did you draw the roof with slopes?  It must be a flat roof, no edge defined slopes, no slope arrows whatsoever.  Then you select the roof and Modify Sub Elements from the ribbon.
To show the layers, turn on Section box and stretch it to cut through the roof.
Nachricht 10 von 11
You, my friend, have shown me the light.  Thank you so much.  Got a big project where this will be the go-to approach. I was oversimplifying the process.
Mike
Nachricht 11 von 11
Aha!! You just solved my problem as well-- thank you! I needed two roof types-- one where the structure and the insulation taper, and one where just the insulation tapers and the structure remains flat. Adding the variable layer solved it for me-- thanks again!!
