Best practice for modeling repetitive steel frame
6 ANTWORTEN 6
Nachricht 1 von 7
atomichavez
1014 Aufrufe, 6 Antworten
Hello guys, I'm transitioning from cad to revit and the project we are dealing with is a steel structure that has a repetitive frame (see images below)
I was wondering what is the most effective way to proceed with this model. My first thought were to create a group out of the frame and then just copy it, but as steel elements/connections cannot be grouped Im struggling to find a solution. I discarded the option of creating a family out of the frame because all the funtionalities of the steel tab are lost in family creation.
I know I could just model everything in the main project file but since we are still in design phase I would like to take advantage of the repetitiveness of the project so the modifications done to a frame are affected all through the project.
Any ideas?
6 ANTWORTEN 6
Nachricht 2 von 7
cbcarch
als Antwort auf: atomichavez
Create a custom Truss. Then just copy it as needed.
That design will be a bit tricky, but I think it can be done.
Start with a standard truss that comes with Revit, save-as, and then create your new custom truss.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 3 von 7
atomichavez
als Antwort auf: cbcarch
okay, I did them as thrusses but the connections I apply to a thruss dont take effect on the other ones, is there a way to include connections into the frame so they will also update when edited?
WhatsApp Image 2018-07-02 at 12.38.03 PM.jpegWhatsApp Image 2018-07-02 at 12.38.47 PM.jpeg
Nachricht 4 von 7
cbcarch
Try "nesting" the connection families into the Truss family. Then load the truss into the project and copy it as needed.
Cliff B. Collins
Nachricht 5 von 7
loboarch
Maybe making the steel "frame" a linked project all on it's own and then instance the linked frame "project" as many times as you need it?
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 6 von 7
als Antwort auf: loboarch
I've done this before...even as links the structures try to join each other.  Gets to be quite a mess.  That was on 2015 though, so maybe it has improved.
Nachricht 7 von 7
atomichavez
It worked like a charm I dont know if there will be any downside of doing this but I will keep you updated
WhatsApp Image 2018-07-02 at 5.43.13 PM.jpegWhatsApp Image 2018-07-02 at 5.44.25 PM.jpeg
 I'm not sure what you mean, the thruss family editor only prompts a limited type of families to be inserted, Im I doing what you suggested?
