Best Practice: Create a spin-off interior project from core and shell project
Message 1 of 8
I was wondering what might be the best practice to create a spin-off project from an existing revit project.
I am doing a core and shell (currently in the construction phase) and I have been hired for parallel planning of some limited interior fit-out. Both are separate contracts, so I would like to keep things cleanly separated.
What is the best way to set this up?
I could obviously copy the current file as it is now and start a new project, but then I would have to implement possible late changes to the core and shell into both projects.
Or would you start a new file and link the existing model? But that might limit my options to make changes to the existing conditions when I am working in the interior file (new wall openings, shafts, etc.)? Also, the interior project is limited to only one floor and linking the model with all floors might make the file unnecessarily heavy?
Or maybe there are other options that I am not thinking of?
Any tips how you would handle this are highly appreciated.
Thank you.
Replies (7)
Message 2 of 8
SteveKStafford
Saw your question at the RevitForum site first. Wrote this there:
Assuming that there is only so much a tenant can do to change the core and shell of the building, I'd be inclined to link that model into a new project. I'd build the interior model so the level is at the same elevation as the one in the shell. In other words I'd change Level 1 to be the same elevation...and the floor(s) below/above adjusted accordingly for context in sections or elevations if necessary/useful.
Avoid modeling things in the core/shell that the tenants can change. If you can't avoid it...just be prepared to modify the core/shell model with Design Options to have a way to keep them but hide them from your interior project. That way the construction process isn't altered but there can be views set to show certain options to eliminate those things from the same area of your interior project using the By Linked Views approach.
Steve Stafford
Message 3 of 8
Thank's for the response.
I guess the linking makes a lot of sense.
Why would you change the levels, though?
Message 4 of 8
SteveKStafford
That way I can link the interior project's model to the core/shell model later if desired using the option Auto-Origin to Origin and it will land at the correct elevation. If not I'd have to move it up to the correct elevation after linking. Besides it is supposed to be inside that shell so having levels that correspond to it seems reasonable to me.
Steve Stafford
Message 5 of 8
Faced the same thing when i was working for New Style Interiors the interior fit out company in dubai
Message 6 of 8
RobDraw
And the solution was?...
Rob
Message 7 of 8
B.Fetzer
What's about a shared project and using workspaces?
Workspace one: Works for Custumer one or core
Workspace two: Works for Custumer two or shell
The steering of workspaces is very easy.
Only my two cents 😉
Kind regards, Bernhard
Message 8 of 8
martijn_pater
Think you could use design options?...
