Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
A file only upgrades to Revit 2017 if it is loaded in Revit 2017 and then saved.
Have you looked at backup filew hich migh still be in Revit 2016?
If you export it to IFC then you loose all the Revit intelligence. I would first try IFC4 as this is the latest IFC version and has the most extended information.
If this does not work then use the IFC2x3, I believe still the most common format
Louis
Please mention Revit version, especially when uploading Revit files.
Hi AAdawi,
I agree with EnlInt’s opinion. So please try to use IFC4 or IFC2x3.
This is one of the reasons to keep folders with archived copies of the models. If anything goes wrong, you lose a relatively small amount of work, not the whole model.
