Hi fellas!
What's your best method for cleaning backups from your Revit families?
We have a *.bat file but it only cleans the current folder, guess there's a better way.
Bat script
"del *.00??.rfa /S /F"
I have used a variant of the below previously, had it set to delete temp files older than one month:
:: --------DELOLD.BAT----------
@Anonymous off
SET OLDERTHAN=%1
IF NOT DEFINED OLDERTHAN GOTO SYNTAX
for /f "tokens=2" %%i in ('date /t') do set thedate=%%i
set dd=%thedate:~0,2%
set mm=%thedate:~3,2%
set yyyy=%thedate:~6,4%
echo Today: %dd%/%mm%/%yyyy% Remove files older than %OLDERTHAN% days
set /A dd=%dd% - %OLDERTHAN%
set /A mm=%mm% + 0
:CHECKDAY
if /I %dd% GTR 0 goto DONE
set /A mm=%mm% - 1
if /I %mm% GTR 0 goto ADJUSTDAY
set /A mm=12
set /A yyyy=%yyyy% - 1
:ADJUSTDAY
if %mm%==1 goto SET31
if %mm%==2 goto LEAPCHK
if %mm%==3 goto SET31
if %mm%==4 goto SET30
if %mm%==5 goto SET31
if %mm%==6 goto SET30
if %mm%==7 goto SET31
if %mm%==8 goto SET31
if %mm%==9 goto SET30
if %mm%==10 goto SET31
if %mm%==11 goto SET30
if %mm%==12 goto SET31
goto SYNTAX
:SET31
set /A dd=31 + %dd%
goto CHECKDAY
:SET30
set /A dd=30 + %dd%
goto CHECKDAY
:LEAPCHK
set /A tt=%yyyy% %% 4
if not %tt%==0 goto SET28
set /A tt=%yyyy% %% 100
if not %tt%==0 goto SET29
set /A tt=%yyyy% %% 400
if %tt%==0 goto SET29
:SET28
set /A dd=28 + %dd%
goto CHECKDAY
:SET29
set /A dd=29 + %dd%
goto CHECKDAY
:DONE
if /i %dd% LSS 10 set dd=0%dd%
if /I %mm% LSS 10 set mm=0%mm%
echo Deleting files created before %dd%/%mm%/%yyyy%
for %%i in (*.0???.rfa) do (
set FileName=%%i
call :PROCESSFILE %%~ti
set mm=
set yyyy=
set dd=
set thedate=
goto EXIT
:SYNTAX
ECHO.
ECHO USAGE:
ECHO DELOLD X
ECHO Where X is the number of days previous to Today.
ECHO.
ECHO EX: "DELOLD 5" Deletes files older than 5 days.
GOTO EXIT
:PROCESSFILE
set temp=%1
set fyyyy=%temp:~6%
set fdd=%temp:~0,2%
set fmm=%temp:~3,2%
:: ECHO %FileName% %fyyyy%/%fmm%/%fdd%
if /I %fyyyy% GTR 2069 set fyyyy=19%temp:~6%
:: | This is where the files are deleted |
:: | Remove the 'rem' before DEL to |
:: | delete. ECHO is used for test. |
if /I %yyyy%/%mm%/%dd% GEQ %fyyyy%/%fmm%/%fdd% (
ECHO %FileName% %fdd%/%fmm%/%fyyyy%
rem DEL %FileName%
set temp=
set fyyyy=
set fmm=
set fdd=
:EXIT
:: ----------END-DELOLD.BAT-------------
Impressive, thanks for sharing!
Does it also clean subfolders? That would be really neat. So that you don't have to copy and run the bat-files for each and every category of families in separate folders.
The variant we used did, the line that starts 'for %%i in (...' selects the files to be examined, that can be edited to look in sub-directories. look at the documentation for 'for' batch command. It can also be nested so we had it run first through all user directories on a PC looking for temp & local folders, then go through each of those folders looking for Revit temp files.
