Bending extrusion with pattern
34 ANTWORTEN 34
Nachricht 1 von 35
3161 Aufrufe, 34 Antworten
Hello, I have a panel made with an extrusion in family. On this panel there is an pattern.
However, now I want to allign that panel to a curved wall.. I was wondering if this is possible...?
34 ANTWORTEN 34
Nachricht 2 von 35
als Antwort auf: Anonymous
Nachricht 3 von 35
It belongs to the framing families, not the truss family.
Nachricht 4 von 35
Are you talking about a Pattern-Based Curtain Panel that that is used in Divided Surfaces?
Nachricht 5 von 35
als Antwort auf: barthbradley
Uhmm no I used family>create: extrusion: made a panel and put the patterns in it
Nachricht 6 von 35
Uhmm no I used family>create: extrusion: made a panel and put the patterns in it. So it became a perforated panel
Nachricht 7 von 35
als Antwort auf: ToanDN
I think you post on the wrong topic?
Nachricht 8 von 35
Can you post the file please so we can see what you are doing?
Nachricht 9 von 35
I attached a file with the problem. So the panel with the pattern should be attached to the curved wall. The panel will be the exterior cladding of the curved wall
Nachricht 10 von 35
Like this?
Nachricht 11 von 35
...or more like this?
Nachricht 12 von 35
if so, Array.
Nachricht 13 von 35
syman2000
Is this what you are aiming for? See attached
Nachricht 14 von 35
More like this! It will be the half of the circle filled with panels. How did you do this?
Nachricht 15 von 35
Nachricht 16 von 35
als Antwort auf: syman2000
yes how can I achieve this? @barthbradley @syman2000
Nachricht 17 von 35
Move the panel to where it should be in relation to the wall's exterior face, and then use the Linear Array Tool to array the Panel in the y-direction, and then Radial Array Tool to array all of the linear arrayed panels about the curved wall's center point axis in the x-direction.  That make sense?
Nachricht 18 von 35
did you notice the RVT that @syman2000 posted?  That's another approach you could use.
Nachricht 19 von 35
Thank you for the explanation! I will try it!
Yes I saw the RVT file, I thought you both used the same method?
Has one method an advantage above the other?
Nachricht 20 von 35
Depends. Are you practiced with Curtain Walls? If not, then I would just Array the one you've already placed in the Project and then call it a day.  :zwinkerndes_Gesicht:
