Bend the PPR pipes in reticulation
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
bandarawaan_19
195 Aufrufe, 5 Antworten
When I draw the Pipe reticulation, I was going to bend the pipe which is usually doing in the AutoCAD but i couldn't found any option for that. I want to draw the pipe like as attached picture
5 ANTWORTEN 5
Nachricht 2 von 6
blank...
als Antwort auf: bandarawaan_19
Out of the box Revit can't do curved pipes. You'll have to do them as in place modeled sweeps.
Nachricht 3 von 6
bandarawaan_19
als Antwort auf: blank...
but can't include the slopes in this method am i right
Nachricht 4 von 6
blank...
You could, by creating sloped reference planes and use them as placement planes.
But honestly, and depending on how much of those pipes you have, I think it would be a nightmare to do it like this.
Hopefully someone will suggest a better way or a plugin that can do this.
There are also flex pipes, but they would be almost equally awful for this.
You'd also have to use some references for slopes, but nothing except start and end point of flex pipes doesn't snap, so it's a lot of manual eyeballing.
Nachricht 5 von 6
bandarawaan_19
Thank you for your support
Nachricht 6 von 6
RSomppi
You might get more suggestions over in the Revit MEP forum. There are several threads on the topic but the bottom line is Revit doesn't do this with pipe.
