Bend Floor
Bend Floor
manickavasakam_selvam
Bend Floor
I want create bend floor like image showed below, But I can't create it. Is there any option for creating it? I want to take area in schedule for it.
Thank you..
Alfredo_Medina
You could add the edge that goes up with the slab edge tool, using a profile with that shape. Then you can schedule the area of the floor in a schedule of floors, and the length of the edge in a schedule of slab edges. If you need the area of the edge, you need a calculated parameter that multiples the length of the slab edge by a number that represents the area of 1 foot of edge.
I imagine the base goes around the room, not just one side, so using Slab edge tool is the right approach.
Yeah, I tried this its working perfectly, Thank you... But I can't directly schedule area from this. But its not big problem because I can schedule its length, so I can calculate area from it. But problem is I want to add this aera with already scheduled floor, is there any possibility to do this?
Create parts from the floor and the slab edge and use a Parts material take off schedule.
