Beginners Question - Views
I'm a new user - like my 4th day, so I'm sure this will be an easy one.  I'm using "Instant Revit's" Commercial Bldg book.  I've created exterior walls and 1st floor interior walls.  My 30' high exterior walls do not show on my 2nd floor plan.  Any ideas what I've done wrong?
How high is the 2nd level?  Are the 30' walls set to top-attached to the floor above?
When doubt, go to elevation or section to see what's going on.
Thank you @ToanDN. The second level is set to 13 feet. I did not think to check if the walls or attached to the second level but I will look into that. I ended up just creating a new second level floor plan and then everything worked as expected.
