beginner's problem
1 ANTWORT 1
Nachricht 1 von 2
216 Aufrufe, 1 Antwort
beginner's problem
i m learning revit 2018 version nowadays.
i made plan in ground floor but when i move to first floor i cant see the reference lines of ground floor on it. i have already turned on the underlay option.
please help me with this.. what should i supposed to do???
Thank you in advance.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Hello, this can happen for a different number of reasons.
Here´s a similar post with a solution you can try. HINT!!!!!! Check the phase and phase filters on each views.
Here´s the post .
https://forums.autodesk.com/t5/revit-architecture-forum/underlay-not-displaying/td-p/6831872
Hope it helps.
