Beams not correctly aligning to custom columns?
1 ANTWORT 1
Nachricht 1 von 2
quivver
185 Aufrufe, 1 Antwort
I am unable to get beams to correctly join on non-standard columns. Either they overflow (overlap) or they are short and leave gaps. What's the solution to this? I tried to find a trim feature but it doesn't work on beams. It's happening on multiple columns in my structure.
Beschriftungen (1)
1 ANTWORT 1
Nachricht 2 von 2
jay_colcombe
als Antwort auf: quivver
I would suggest here that you have a play around with the Location Lines of the Beam (Y/Z Justifications) to force the beam onto the column and find a point which is recognised so the automatic clean-up can apply
Jay Colcombe
Autodesk Certified Instructor
