beam,slab,coloumn lines in ELEVATIONS
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
3425 Aufrufe, 9 Antworten
according to the attachment the elevation view is showing the beam,wall,slab lines in hidden line visual style.
but i need to know a method for this issue without using invisible line method.
9 ANTWORTEN 9
Nachricht 2 von 10
bin
als Antwort auf: Anonymous
Can you please screenshot the properties of this view?
Nachricht 3 von 10
indiana_j0nes
Duplicate the view and make it a coordination view and allow 'Show Hidden Lines'
Hope this is what your looking for.
Cheers, K
Kunal Tuljaram Gaidhankar
Nachricht 4 von 10
for final drawings, i need to get rid of these lines. (these are wall,column lines). iun architectural drawings the elevation view canot be seen as this. if you didnt understand my question, i'm very sorry i have language problem.
Nachricht 5 von 10
indiana_j0nes
Oh okay, my bad I misunderstood.
as@bin pointed out earlier.
Could you share a screenshot of the Properties Panel for this view?
Nachricht 6 von 10
Switch them off in VG.
Nachricht 7 von 10
Karol_Piroska
are the walls/slabs behind? If so it looks like your wall has transparency applied (check element overrides - manual, vg or filters), otherwise the lines would be dashed. Or maybe you have slabs/walls joined to wall such that they cut your wall.
If the wall is not transparent, walls/slabs are not joined to the wall and all are behind the wall on elevation; try to switch to different discipline (architectural, coordination) and make sure "show hidden lines" in properties panel is set to show none.
Nachricht 8 von 10
als Antwort auf: indiana_j0nes
i uploaded the revit properties and 3D view.
i want to know how how to get rid of these wall beam column line in my elevation view.
Nachricht 9 von 10
als Antwort auf: Karol_Piroska
i will upload some 3D views to understand the model. when in the elevation view i need to get rid of these wall,column, beam lines
Nachricht 10 von 10
Karol_Piroska
@Anonymous the beams/columns/slabs are clearly cutting your walls. So or the wall is in wrong position or it simply has no outer leaf (external layer of a compound/cavity wall), so obviously all these elements are and have to be visible. All these elements have different materials therefore you cannot "join" them. If the geometry is correct (wall infills between slabs/columns/beams and you are not showing the cladding or outer leaf), I'd say the only way would be to manually override lines to invisible lines or add a filled region and lock the boundary to building edges.
