Beam on floor plan 1 doesn't show on plan 2 underlay
7 ANTWORTEN 7
Nachricht 1 von 8
563 Aufrufe, 7 Antworten
Problem as follows:
Beam placed on floor plan 1. Floor plan 2 underlay base level "floor plan 1" and top level "floor plan 2". Underlay look down. Yet the beam doesn't show on floor 2. Can anyone explain this to me? If i place a wall on floor 1, make it unconnected with height 100 mm it shows up on floor 2 as half tone.
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: Anonymous
hello, try to adjust setting of your view range > bottom and view depth level anf see if helps. thanks
Nachricht 3 von 8
als Antwort auf: ennujozlagam
?Yes but I dont't want to change the view range. I want it to show up when I use the underlay function. I can see the wall on floor 1 that has the same height as the beam so why cant i see the beam?
Nachricht 4 von 8
ennujozlagam
then use plan view region and change setting. thanks
Nachricht 5 von 8
?Ok thanks that will work but I would still like to know why the beam doesn't show up when the wall does so. Any explanation to that?
Nachricht 6 von 8
Is it a grade beam? In other words, is it below the Level?  Is the Detail Level of Level 2 set to Course?
Nachricht 7 von 8
RobDraw
Is the beam visible in the floor plan?
What happens if you change the underlay to look up?
Rob
Nachricht 8 von 8
als Antwort auf: RobDraw
Thank you all for suggestions. I now solved it myself and it was a rather easy fix. I had put the z-justification of the beam to "top" and I didn't notice that it then was under the floor level.
