Beam Non-typical Beam Joins
6 ANTWORTEN 6
Nachricht 1 von 7
PhilvK
406 Aufrufe, 6 Antworten
I have a condition where I need to have some short 4x4s connect to other 4x4s perpendicular to the short ones, and at different heights. I used reference plans (highlighted below) and ‘cut geometry’ to get the shorter members to frame cleanly to the sides of the longer ones. Is there an easier way? I tried doing this with ‘beam joins’, but that didn’t seem to work. Thank you. Illustrations of this are below.3D3DElevationElevation
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: PhilvK
What are you wanting to do?  Want do you mean by "cleanly" join?
Nachricht 3 von 7
PhilvK
als Antwort auf: barthbradley
I would like the sloping members to fit flush to the sides of the horizontals ones as shown in the 2 sketches in my original post. Without cutting the geometry, I get gaps between the members as shown below.
Nachricht 4 von 7
Well then, you need a beam family that is shaped that way.
Nachricht 5 von 7
What you did is a clever way to deal with it.
Nachricht 6 von 7
You can also use Opening by face tool to trim the beams.
Nachricht 7 von 7
PhilvK
als Antwort auf: ToanDN
Thank you both. I'll need to look at how to get a beam shaped that way, and how Opening By Face works.
