Beam lenght problem
1 ANTWORT 1
Nachricht 1 von 2
giovvy88
208 Aufrufe, 1 Antwort
Beam lenght problem
I'm trying to place a beam and i need that its edge is aligned to the reference plane but i don't understand why the manipulation point is a little inside from the edge of the beam. Can someone help me?
1 ANTWORT 1
Nachricht 2 von 2
alan.johnson7YLND
als Antwort auf: giovvy88
I believe that is the start/end join cutback which is 12.7mm but you cant edit that property (in the project)for a concrete beam.
If you edit the family you can see the ref planes for the join cutback.
